wisemonkey Posted March 30, 2025 Posted March 30, 2025 Morning all, Our Ikea integrated washing machine was making a knocking noise when the drum was turning. On removing the back, I've discovered that it's the pulley knocking against the back of the drum. It's almost as if the bot isn't tight, so it's not keeping the pulley hard up against where it's met the drum. I removed the bolt, and and looked at the pulley, nothing appears to be missing, although I note on replacement pulley kits, theres a large washer and a smaller washer - I only have a larger washer. This is the pulley I have https://www.amazon.co.uk/AEG-WASHING-MACHINE-PLASTIC-PULLEY/dp/B084C3S7JB?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3MYEF0XBKZGAV&gQT=1 The rocking of the pulley is causing a knock as it rattles, and also causing the belt to slip towards the back of the pulley and its occasionally falling off. Is it normal of the pulley to act loose? Thanks in advance.
Root Admin Whitegoodshelp Posted March 30, 2025 Root Admin Posted March 30, 2025 Hi. This is a known fault. A new Drum pulley should fix it Knocking tapping noise on spin wisemonkey 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
