Philo Posted October 15, 2024 Posted October 15, 2024 Hi, the emergency drain hose has retracted back into my beko washing machine - the cap is off it - my question is can I still use it while I figure out how to retrieve it or will it flood the kitchen ?
Root Admin Whitegoodshelp Posted October 16, 2024 Root Admin Posted October 16, 2024 Hi. If the cap is off, it will flood out of the hose if water is put into the washing machine. You might have to remove the plastic kick strip to retrieve it. It should come off easily. Maybe a couple of screws, or often just gently levering it away with a flat bladed screwdriver from the top. There are various ways that the kick strip should come off but it should be easy to work out how to do it. The kickstrip is the plastic surround at the bottom of the front of the washing machine. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
