Neil Bourhill Posted September 17, 2024 Posted September 17, 2024 This is our 3rd Miele Washing Machine and replaced our last one that stopped working for no reason in July 2024. Miele engineer came out and to cut a long story short we purchased a new machine. He suggested sitting the new machine on a concrete slab as we have a wooden floor (all the machines have been on wooden floors). The new machine sits in a cupboard on a wooden floor, 6mm plywood, Amtico flooring, 20mm damper and a 50mm concrete slab. And still makes a terrible noise when spinning. The engineer has been out and blames the wooden floor for the noise. I have sent emails back and forward to the customer service team, but keep getting the same reply. The wooden floor. We follow the instruction manual for program choices and even weigh the washing before loading. The previous machine lasted 8 years and I can't see this one lasting that long. Any suggestions? 20240908_150534.mp4
Root Admin Whitegoodshelp Posted September 17, 2024 Root Admin Posted September 17, 2024 Hi. My Miele made the exact same sound. It sounds like the noise made when the washing machine isn't level. I can see it rocking up and down, albeit slightly. When it's on spin like this, does the noise stop if you firmly press down on the lid? If necessary or appropriate, try sitting on it even. It should stop if you adjust one or more of the feet so it's dead level. Ideally, use a spirit level to make it level from side to side and front and back. But mainly just get it so that it cannot rock even a millimetre either front and back or side to side. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Neil Bourhill Posted September 17, 2024 Author Posted September 17, 2024 4 hours ago, Whitegoodshelp (Andy) said: Hi. My Miele made the exact same sound. It sounds like the noise made when the washing machine isn't level. I can see it rocking up and down, albeit slightly. When it's on spin like this, does the noise stop if you firmly press down on the lid? If necessary or appropriate, try sitting on it even. It should stop if you adjust one or more of the feet so it's dead level. Ideally, use a spirit level to make it level from side to side and front and back. But mainly just get it so that it cannot rock even a millimetre either front and back or side to side. Andy, thank you for your feedback. Yes it's level and I asked the Miele Engineer if it was level enough and he said yes. I sent the video to Miele and the engineer has seen the video but still says it's the floor. I'll try sitting on it tomorrow. But it should not make that noise, it's sounds like metal hitting metal.
Root Admin Whitegoodshelp Posted September 18, 2024 Root Admin Posted September 18, 2024 Strange, it sounds exactly like mine did — and I can see the washing machine rocking very slightly. It might well be level, but are all 4 feet firmly on the ground so that the washing machine cannot be rocked in any way and is rock solid? With me, it was just one foot that was only just touching the floor or was a millimetre off the floor. Winding the foot out, so that it made proper floor contact, stopped the noise. The noise was caused by the machine moving a millimetre side to side rocking on the foot rapidly. The foot was hitting the floor many times a minute. I can see it happening with yours. The offending foot seems to be on the left side. I can see the washer rock slightly to the right and then drop back down on one or both of the left feet, and then doing it over and over at high speed. This can happen, but you can still get a perfect reading on a spirit level. If I am right, the noise would stop if you sit on it or maybe press firmly down on it. Other than that, make sure the two steel transit packaging rods have been removed. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Neil Bourhill Posted September 18, 2024 Author Posted September 18, 2024 2 hours ago, Whitegoodshelp (Andy) said: Strange, it sounds exactly like mine did — and I can see the washing machine rocking very slightly. It might well be level, but are all 4 feet firmly on the ground so that the washing machine cannot be rocked in any way and is rock solid? With me, it was just one foot that was only just touching the floor or was a millimetre off the floor. Winding the foot out, so that it made proper floor contact, stopped the noise. The noise was caused by the machine moving a millimetre side to side rocking on the foot rapidly. The foot was hitting the floor many times a minute. I can see it happening with yours. The offending foot seems to be on the left side. I can see the washer rock slightly to the right and then drop back down on one or both of the left feet, and then doing it over and over at high speed. This can happen, but you can still get a perfect reading on a spirit level. If I am right, the noise would stop if you sit on it or maybe press firmly down on it. Other than that, make sure the two steel transit packaging rods have been removed. I did sit on the machine twice today and it was quieter the first time but the metal knocking sound was there the second time. To get the machine level ( facing the door ) I left the feet on the right as set at the factory and the feet on the left 3 full turns out, to get it level. I will check the level again tomorrow and try to adjust one foot on the left. I don't have a lot of space either side as it sits in a walk-in cupboard, with brick walls either side and behind the machine. When the Miele Engineer came to look at the machine. He never checked if it was level or stable, just took my word for it. Also I thought that he would have put it through a wash/spin cycle, to hear the noise but no and just said it's the wooden floor. And yes the transit bars are out.
