I have hisense washing machine wfhv7012 main board DSG A24,
It running usually today but before the end of the program by 10 minutes it stops and the display becomes off, when I put the control switch off then when I try to switch it on again nothing on the display but just a relay sound (on off)
Note: I didn't see anything blowing on the board.
Hi. Sounds like a power issue. First thing to discount is the wall socket. Try a totally different wall socket. I've had appliances just die halfway through running caused by loose connection in wiring in wall socket. Other than that it could be tricky to sort out. Could be a dry joint, loose connection somewhere or a fault in the PCB or control panel. Could even be a problem on the on off switch or door lock.
