newboy Posted June 15, 2023 Posted June 15, 2023 I put my machine on this morning, it was quite loud and making a squeaking noise as if something is rubbing. I tried to force the cycle to complete and now it's stuck. I've turned it off at the mans but it just goes back to the cycle. I've tired changing the cycle again no joy. At one point I got the door open, the clothes were wet (obviously) and the drum could not move when it would do normally. Any ideas please?
Root Admin Whitegoodshelp Posted June 15, 2023 Root Admin Posted June 15, 2023 Sounds like the drum is jammed. If it's been very noisy recently, the drum bearings could have failed but if not something could have gone inside and jammed it up, or some item of laundry could have got stuck between the front lip of the drum and the back of the door seal. newboy 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
newboy Posted June 15, 2023 Author Posted June 15, 2023 Ok thanks, I can have a rummage around and see if anything is obvious but I feel I may need more of an expert. I have a local guy, I might give him a shout. Whitegoodshelp 1
