Hi I have a Bosch washing machine that keeps filling when starting a wash. Tried blowing down the pressure switch hose. All ok. Can hear pressure switch switching. Tested with continuity and it is switching. Also replaced the water inlet solenoid. Any help would be greatly appreciated. Thanks.
Hello Tom. Presumably you mean that it is overfilling, and doesn't stop taking in water? Check out this article Washing machine overfills
Hi yes it overfills. Just takes in water when you start a wash until it gets to a point then it drains it out and starts again. The air is getting to the pressure switch as I can hear it click but it’s not shutting the valve.
