Wetclothes Posted May 22, 2023 Posted May 22, 2023 Hi all I've got a Miele WT2780 and the clothes are coming out wet. There is no water at all in the drum however the clothes are very wet so it seems to be an issue with the spin dry. I opened the front capsule / filter thing, let all the water drain and checked for a blockage. I took off the drainage pipe to check for blockages. I can pour water right through the drainage pipe so I guess there is no blockage. I reattached the drainage pipe in a straight line going to a bowl just in case there was some sort of bend but the result is the same. Even though the spin cycle sounds normal and finishes without errors I noticed that the clothes don't move they stay still during the spin cycle. Anything else I can try? Thanks
Root Admin Whitegoodshelp Posted May 23, 2023 Root Admin Posted May 23, 2023 Hello there. If the drum isn't turning at all during the cycle then the motor isn't running, or the drive belt has come off. There are many possible causes for this, all listed in detail here Washing machines drum does not revolve during the wash rinse or spin Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
