laura87 Posted May 1, 2023 Posted May 1, 2023 I just did a normal wash, nothing different than usual. When the spin got faster it made an almighty banging sound. When it finished, the clothes were soaking wet and there were bits of thin white plastic all over the clothes. The drum doesn't feel particularly loose but there is a lot more resistance, and grinding when you try to manually spin it. Grateful for any ideas before I book an engineer. Thank you
Root Admin Whitegoodshelp Posted May 1, 2023 Root Admin Posted May 1, 2023 Hi. It sounds like something metal could have got inside, such as coins from pockets, or possibly the drum has broken or drum bearing collapsed. If the washing machine was not previously noisy I’d suspect the first one. if it’s been rumbling a lately it could be drum bearings, though they don’t usually go so suddenly. It could be very expensive if the drum is damaged. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
laura87 Posted May 1, 2023 Author Posted May 1, 2023 4 minutes ago, Whitegoodshelp (Andy) said: Hi. It sounds like something metal could have got inside, such as coins from pockets, or possibly the drum has broken or drum bearing collapsed. If the washing machine was not previously noisy I’d suspect the first one. if it’s been rumbling a lately it could be drum bearings, though they don’t usually go so suddenly. It could be very expensive if the drum is damaged. Thank you, how would I check if something has got inside? I've actually just run my hand round the rubber lining and I think it's come away at the top, it is does feel quote loose if you push the top of the drum
Root Admin Whitegoodshelp Posted May 1, 2023 Root Admin Posted May 1, 2023 An engineer would tip it back and forth and side to side to see if they can hear anything sliding about, and check inside the sump hose. If the door seal has come off maybe the drum just went crazy from a very badly balanced load. Unfortunately it’s likely to need someone who knows what they are looking for to thoroughly examine it. It’s pretty much impossible to accurately work out what went wrong and why unless you are an experienced engineer. laura87 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
