JLivingstonSG Posted April 22, 2023 Posted April 22, 2023 Hi. I have a hoover washing machine wdyn 9646pg-30s and I got a error code that said I need to change the door lock. So I did. Now if I power it up it shut down after 15 seconds. No error codes. If I then push power again I hear a click and can now power up it. But it only stay alive for 15 seconds then shut down. If I start a program it run the whole program and end and all is fine. No error codes. If I start a drying program, it shut down and only the led is red. If I power off then the red led is off. No error codes. What is the problem? Can I reset it some way? Is a dryer sensor damaged ? Regards Magnus -------------------------------------------
Root Admin Whitegoodshelp Posted April 24, 2023 Root Admin Posted April 24, 2023 Hello. If there is a fault, then once the fault has been cleared, any error codes should stop being displayed. You should not normally have to reset anything. The only thing I can suggest is that you try plugging it into a completely different wall socket, even if it means temporarily using a 13 amp extension cable. It sounds like some sort of power supply problem, though it is a very unusual set of symptoms. To try and find out if it still has anything to do with the door lock, take a note of the control panel display when the washing machine is switched on, but with the door open. If the fault is on the door lock then you would expect the control panel to revert to this state if for example the door lock wasn't passing power properly. But if the whole control panel cuts out when it is playing up, then this would imply that the fault is not caused by the door lock. If the fault is the same in a different wall socket then it is difficult to offer any further advice because it could be a very unusual connection fault somewhere, or a fault inside the main PCB, or even the control panel itself and you cannot really just start replacing those kinds of parts in the hope that it will fix the fault. They are too expensive. JLivingstonSG 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
JLivingstonSG Posted April 26, 2023 Author Posted April 26, 2023 Thanks. It work if I just start it as fast as I can when powering up. It is working now. But if I just turn it on it just shut down as if it loos power. When I press power again I hear a click and when I again press power it turns on. Then if I do not start any program, it shut down after about 15 seconds. Some times if I try to start a program it get hanging in a flashing mode so that power light and program light is flashing. Only way is then to pull the power plugg. But it is now washing and I now wait to see if the drying program will start after washing program. I measured the voltage and it is fine. But I will try to get power from another outlet to see if it helps. If anyone have had this problem or something similarly then please let me know. Regards ..... Magnus
Root Admin Whitegoodshelp Posted April 26, 2023 Root Admin Posted April 26, 2023 It could be a relay problem in the pcb but that’s just a guess. JLivingstonSG 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
JLivingstonSG Posted April 26, 2023 Author Posted April 26, 2023 Anyone know what relay in the pcb I need to get? Is there only one relay in the pcb? Am I to just listen to the machine, to find out what relay is clicking? Regards MagI
Root Admin Whitegoodshelp Posted April 26, 2023 Root Admin Posted April 26, 2023 If the clicking is coming from the pcb it could be a relay but if it’s clicking it shows it is working - unless there is a connection fault or maybe it doesn’t stay activated. But you can’t buy any parts for a washing machine pcb at all. Only a complete pcb at great expense. Some of them even need programming. I would not get involved in speculatively changing parts. JLivingstonSG 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
JLivingstonSG Posted May 7, 2023 Author Posted May 7, 2023 If I just power it up it shut down and dies after about 15 seconds. Then when I power on it click and lights up but again dies and shut down after about 15 seconds. But if I start a program as quick as possible before it dies/shut down it work perfect. Both washing and drying program work and is stay alive after the program is done. But then after power off, its the same problem. Can it still be low voltage ? Or a damaged relay? Whats going on? MagI -------
Root Admin Whitegoodshelp Posted May 9, 2023 Root Admin Posted May 9, 2023 Hello there. Unfortunately this is an extremely weird fault and not really suitable for DIY repairs. An engineer looking at something like this that was still under guarantee may well try replacing the control panel, and or the PCB. This may, or may not fix it, but at least an engineer would be able to order the parts without it costing them money. For you to order parts like this would be a very big gamble indeed and not to be recommended. I can't see how it could be low-voltage because low voltage would prevent it from working at all. Maybe for some reason when you first switch it on it is doing some self checks, as computers often do, and maybe it is failing some check and shutting down. At the end of the day you just can't fix something like this without access to parts, and technical information. JLivingstonSG 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
JLivingstonSG Posted May 18, 2023 Author Posted May 18, 2023 ---------------- I have a seriously low water pressure to the washing machine. Can that have anything to do with my problem? Regards MagI --------------------------------------
Root Admin Whitegoodshelp Posted May 18, 2023 Root Admin Posted May 18, 2023 With water pressure that’s too low, a washing machine will try to fill, the drum may turn several times, but eventually time out with an error code that indicates a water supply problem. This error code is often something like E1 or H20 (as in H 2 O for water). Low water pressure would take much longer than 15 seconds to time out with an error, and if water pressure is so low it causes a fault it couldn’t possibly work OK when you start the cycle quickly. JLivingstonSG 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
JLivingstonSG Posted May 20, 2023 Author Posted May 20, 2023 On 18/05/2023 at 19:08, Whitegoodshelp (Andy) said: With water pressure that’s too low, a washing machine will try to fill, the drum may turn several times, but eventually time out with an error code that indicates a water supply problem. This error code is often something like E1 or H20 (as in H 2 O for water). Low water pressure would take much longer than 15 seconds to time out with an error, and if water pressure is so low it causes a fault it couldn’t possibly work OK when you start the cycle quickly. I never get a error code after 15 sec. It just shut down. When I press the power button out , then I hear a click from it. Then when I power on it again stay live about 15 sec , and then shut down dead, if I do not start a program. But I have to start a program fast because if I am to slow it just dies. No error codes. Sometimes it freak out and start flicker on panel. Then I need to cut the power cord. Then it is the same again. Crazy.......... Regards MagI ----------
Root Admin Whitegoodshelp Posted May 20, 2023 Root Admin Posted May 20, 2023 Yes it looks like one of those false that you are not likely to be able to repair yourself. It could be a problem with the PCB, although the control panel, or both, or a connection fault between them. But even something else. Faults like this need an engineer. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
