I have a Bosch Varioperfect 4 and until yesterday I've had no issues with it.
After a regular cotton wash cycle, the machine hung on 1 minute remaining and just sloshed the laundry and water around the drum with no drainage. This continued for at least 20 minutes.
I turned the machine off and drained through the front-panel hose. I also opened the filter which was full of water but otherwise no physical blockage. I then ran a 15-minute superquick wash cycle which worked fine, and I could see it draining (I can physically see the output outside my house).
I then put on another regular cotton cycle and again it hung on 1 minute remaining for at least 10 minutes and just refused to drain. I turned the machine off, then this time instead of manually draining I just put the machine on a spin & drain cycle - it instantly drained all the water and worked as expected.
I'm not sure how to go about fixing this - there doesn't seem to be a physical problem with the pump or the machine draining, it just refuses to do so at the end of wash cycles.
Hi. There have been several people with this problem across different brands of washing machine. I don't think there is a definitive answer, but read all the previous topics which might help - stuck on one minute
