EvanG Posted March 24, 2023 Posted March 24, 2023 Hey Guys, My washing machine kept throwing h2o errors on start up. There was no water getting to the machine. I went ahead and replaced the solenoid and water seems to be getting to the machine. Problem is it throws this h2o error every few minutes. I've attached a video of this. Any help would be hugely appreciated Thanks 🙏 Snapchat-2140461546.mp4
Root Admin Whitegoodshelp Posted March 24, 2023 Root Admin Posted March 24, 2023 Hi Evan. H20 usually means it's not detected any water. However, it should take a couple of minutes before it decides there is a fault. This is because when it starts to fill with water it starts to time the process, and should only decide there's an error after it times out and to should allow a reasonable amount of time. If water is running into the machine could it be siphoning out? This could happen if the drain hose pushes into a standpipe and the hose is pushed in too far. How long does it fill before it gives the error after starting to fill? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
EvanG Posted March 24, 2023 Author Posted March 24, 2023 Hi Andy, Thanks alot for that tip. The hose in the stand pipe was too far down. This has resolved the issue. Thanks for the help Kind Regards, Evan Whitegoodshelp 1
Root Admin Whitegoodshelp Posted March 24, 2023 Root Admin Posted March 24, 2023 Nice one 😊 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
