chesterflaps Posted November 20, 2022 Posted November 20, 2022 Hi all. I bought a Haier HW90 washing machine in June this year and had no issues until about 2 weeks ago. My clothes smell foisty after washing yet a couple of weeks ago, I could smell the clean washing throughout my house whilst is was drying. I used some washing machine cleaner and nothing changed. I decided to check the temperature of the washing during the cycle to see if it was getting hot and it appears not. I assumed the heating element had failed so I got a replacement sent out. I am still having the same issue of a foisty smell with the new washer. I have a wash on now and I have paused it several times and each time the washing is extremely cold to the touch even though it is on a 40 degree wash. I would expect the washing to be warm if the water washing it is meant to be 40 degrees. I wondered if the water is only heated for a short period of time during the cycle and I just so happen to be checking outside of those times. Any help would be appreciated as I cannot stand to have clothes smelling like this.
Root Admin Whitegoodshelp Posted November 21, 2022 Root Admin Posted November 21, 2022 Hello there. I would say that even if it definitely wasn't heating, it would be unwise to assume it needed a new heating element. There are several other possible causes. It's very strange because if a modern washing machine fails to heat the water, then they should be able to work that out. They should then abort the wash cycle and produce an error code. This is extremely easy to do because they are all controlled by little minicomputer software programs that can check the temperature of the water every few minutes to make sure it is rising. So in theory, it should be impossible for a washing machine that completes a full cycle in the normal timeframe to have any fault. However, I have seen strange anomalies where washing machines have bizarrely been unable to detect a fault and therefore carried out bizarre behaviour. The water should begin to be heated up virtually straight away. After 15 minutes or so, the water should be noticeably warmer. However, due to the fact that the water levels in modern washing machines are extremely low, causing virtually no water to be splashing around the door glass, and the fact that many washing machines have a sort of double glazed door, it is possible to be unable to feel any heat. There is only a short window where the water inside the washing machine is fairly hot and that's roughly somewhere between 10 and 25 minutes depending on the wash cycle. After that the water is stone cold. The best way to be sure if it is heating up water or not would be to put it on a 60° cottons wash cycle. Then stop the washing machine after 20 minutes and see if you can open the door after the door lock has cooled down. Water levels on modern washing machines are usually nowhere near high enough to spell out if the door is opened. Then check the temperature of the water. Obviously be aware that if by any chance you caught the water when it was above 40° then the water could potentially burn. Alternatively, a safer, but more involved method would be to just cancel the wash cycle after 20 minutes and then try to observe if the water being pumped away has been heated up or not. The latter method could be very easy to do, or very tricky to do depending on how it's plumbed in and where it's plumbed in. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
chesterflaps Posted November 26, 2022 Author Posted November 26, 2022 Thank you. I have checked a few times and the water never seems to be hot but this is the second washing machine we have had so I can't imagine both are faulty. The smell isn't quite as bad with the replacement one but it's definitely still there. Could it be anything to do with the waste pipe? I though the waste had to enter the pipework under the sink, above the trap. As you will see from my.picture, mine doesn't.
Root Admin Whitegoodshelp Posted November 26, 2022 Root Admin Posted November 26, 2022 Hi. Yes if 2 separate washing machines have the same, fault it's very to be something to do with installation. Your washing machine drain hose seems to be attached to the bottom of a pipe with no u-bend? A u-bend is essential for preventing smells from the drain going back into the washing machine. My article here explains it, so have a read and see if it helps https://www.whitegoodshelp.co.uk/smells-caused-plumbing-faults/ Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
