Machine not draining, no blockage, drain pump impeller just sitting oscillating slighlty. E03 error
Could turn drain impeller by hand but felt stiff.
Took off pump to check, looked ok, nothing at rear of impeller, felt tight/loose when rotating.
After refit & power back on the display is not normal, just like dashes going round, see attached vid.
Hi Mike. The true test will be if it works OK now? BTW the pump impellers are normally a little stiff. They sort of turn then suddenly free off and then go stiff again. I think it's turning through a magnet.
