mpp121 Posted September 29, 2022 Posted September 29, 2022 Hi everyone, I have a Bosch washer dryer WVG30461GB. Recently drying started to fail - after a "Gentle dry" programme, I will find the clothes hot and very wet - arguably more wet than they were before I started the run. The machine initially says the programme will take 2.5 hours, however I noticed that when it gets to ~30 mins remaining, it will put more time and it will actually take 3 hours in total. I checked the pump filter and it seems clean. Also, there are no error codes. One repairer I called said that probably too much fluff accumulated since I did not really know I was supposed to run the drum clean programme often. And that fixing it now requires disassembling the machine, which is a 350-400£ job. I tried running the drum clean programme multiple times now, but it does not seem to bring the drying back. I wanted to ask for a second opinion here, or if anyone has had this issue before. Thanks!
Root Admin Whitegoodshelp Posted September 29, 2022 Root Admin Posted September 29, 2022 Hi, this article explains possible causes of laundry comes out of washer dryer hot & steamy which should give a good idea of the potential issues. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
