Ihaveaproblemwithmywasher Posted August 4, 2022 Posted August 4, 2022 Hi there, I have a problem with my Beko washing machine. It won't start any programs and keeps flashing between the time and the word "end" when I try to start it. I already tried the 3" reset and on the diagnostics it tells me there's an error - the code is F08. When I try to go through the tests, nothing happens. Does anyone know what this error code means and if I would be able to fix it? Thank you so much for your help!
Root Admin Whitegoodshelp Posted August 5, 2022 Root Admin Posted August 5, 2022 Hi. Reset will only work if the error is fixed. I have quite a few Beko error code explanations, but they all use E, not F. Is it definitely F08 and not E08? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Ihaveaproblemwithmywasher Posted August 8, 2022 Author Posted August 8, 2022 On 05/08/2022 at 21:29, Whitegoodshelp (Andy) said: Hi. Reset will only work if the error is fixed. I have quite a few Beko error code explanations, but they all use E, not F. Is it definitely F08 and not E08? Hi, yes, it's definitely F08. I've seen lots of posts online about E08 but I think that our model is older and that that must be the reason why.
Root Admin Whitegoodshelp Posted August 8, 2022 Root Admin Posted August 8, 2022 On 04/08/2022 at 11:34, Ihaveaproblemwithmywasher said: I already tried the 3" reset and on the diagnostics it tells me there's an error - the code is F08. If you are not actually seeing the error code F08 now, and have only retrieved that error code by carrying out some key presses to go into a diagnostics mode, then it's possible that F08 was the last error code from a previous fault. And therefore that this current fault is something different, and one that is not displaying an error code. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
