Curious Posted May 19, 2006 Posted May 19, 2006 While looking at the washer I noticed that there is a small hole (like a tear) in the rubber door seal. Should this be cause for concern?
Root Admin Whitegoodshelp Posted May 19, 2006 Root Admin Posted May 19, 2006 With a small hole or tear, if the rest of the door seal is in very good condition, I've occasionally done succesful repairs using a bicycle repair kit. I peel away the door seal from the washing machine casing and do the repair on the outside of the door seal where it won't be subjected to the water. Fixing a patch on the inside usually results in them coming off eventually. However, if the washing machine is young (and expected to last a fair bit longer) or the rest of the door seal isn't so good it would be better to replace the door seal. ( Related: Links to buy washing machine door seals and other parts online - Washing machine and appliance spares ) Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted May 19, 2006 Author Posted May 19, 2006 Well, fingers crossed it all looks to have gone ok. The door seal has been replaced. We had some fun getting the door seal off, and even more fun fitting the door attachment so that the door would actually close, but all seems to be running fine now. Thanks so much for your help, you've saved us buying a new washer! I've sent a donation (as should everybody else who's problems are solved by washerhelp)
