Nikaum Posted July 9, 2022 Posted July 9, 2022 Hi all, My washer, model in the title, is permanently stuck at 1 minute, no spin light on. When I run it, it actually gets "Done", but when I turn it on again to try to set up a load, it shows me the same 1 minute and no spin light turned on. See image attached. I already manually put water in and ran this 1 minute and the pump works fine, therefore, shouldn't be a pump issue. Of course i already tried to unplug the machine for minutes, even hours, but when i plug it back in, the same 1 minute "no spin" shows in the display. Any clues what might be going on? Thanks! Nicolas.
Root Admin Whitegoodshelp Posted July 12, 2022 Root Admin Posted July 12, 2022 On 09/07/2022 at 22:17, Nikaum said: When I run it, it actually gets "Done" Hi. Do you mean that it otherwise works okay? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
