So i noticed a leak coming from under the washing machine and isolated the leak to the sump hose connection area. We removed the sump hose,it was clean, with no blockages or obvious holes. After numerous attempts to refit and tightening the clamp, it still sprung a leak. Ordered a new hose and still, the problem reoccurs. There are no obvious holes in the sump itself. I'm wondering if I'm not lining up the sump hose properly, any thoughts on what could be causing the issues?
  • 1 year later...
Hi Did you find out the solution to this? Mine is doing the same thing.
