andyr12345 Posted June 5, 2022 Posted June 5, 2022 (edited) Hi Andy. Have you heard of the rubber drive belt from motor spindle to drum pulley making noises when they are brand new? This new Samsung (well was new in February) washing machine does not have direct drive but it has got a quiet inverter motor fitted. - If I open up the washing machine door and spin the drum by the paddles slowly by hand I can hear 'creaking' noise , Could it be a possibility that the belt is so brand new its making a noise and that when its 'worn in' (a couple of years lol) it will be quieter ? I turn the drum of our old Hotpoint washing machine drum and cannot hear the belt 'creaking' on that - but that was bought in 2012 so its getting on now . I could I suppose , as way of elimination, take off the drive belt off the new Samsung and then spin the drum with my hand and see if the 'creaking' noise is still there (but then I suppose it would then void the warranty on the washing machine , so I better not do that then Edited June 5, 2022 by andyr12345 changed title a bit
Root Admin Whitegoodshelp Posted June 5, 2022 Root Admin Posted June 5, 2022 Hi Andy. I used to find new drive belts that I fitted often had an annoying squeak. To be fair they were usually the cheaper none genuine ones that were more rubbery. I used to spray a very small amount of WD-40 on it. However, I didn’t use the straw, I wanted a mist of WD-40, and I was careful to not let any get on the motor bearing! I’m not sure how long it lasted, but it certainly instantly stopped the squeaking. You could try it to at least see if it stops the squeak, and therefore prove the source. You really don’t need much though. andyr12345 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
andyr12345 Posted June 5, 2022 Author Posted June 5, 2022 Thanks for that tip Andy, might be worth a go. I thought WD40 ate into rubber , but in the house somewhere I have some silicone spray (also made by WD40) and I think silicone spray is supposed to safe to use on rubber. Yeah, think I will give that a try one day (if it doesn't void the warranty) - what you reckon could it?
Root Admin Whitegoodshelp Posted June 5, 2022 Root Admin Posted June 5, 2022 I’m pretty confident WD-40 is perfectly safe on anything, except bearings where it would thin out the grease Andy. andyr12345 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
