Blair1411 Posted May 30, 2022 Posted May 30, 2022 So my beko washer dryer has been running for like an hour or 2 after cycles. I've done the usual and checked the drain filter is clear, the pump impeller spins. Is there a way to run diagnostics for fault codes? Or any other direction I can be pointed in?
Root Admin Whitegoodshelp Posted May 30, 2022 Root Admin Posted May 30, 2022 Does it have a solid base and a float switch to detect leaks? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Blair1411 Posted May 30, 2022 Author Posted May 30, 2022 3 minutes ago, Whitegoodshelp (Andy) said: Does it have a solid base and a float switch to detect leaks? Yes it's on a solid base, where would I find the float switch? I'm planning on stripping it to look for further indicators tomorrow.
Root Admin Whitegoodshelp Posted May 30, 2022 Root Admin Posted May 30, 2022 In the base. If one is fitted it will be obvious. If there’s a leak it can switch the float switch on and energise the pump. They can also stick on. It’s a long shot really though, as in theory if it detects a leak, it should really abort the cycle. So if it otherwise works ok it may be something else. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
