Siemens2022 Posted April 18, 2022 Posted April 18, 2022 Hi, I have a 6 month old Siemens IQ700 washing machine that gave up today, issue is its not draining the water in the end and giving E:36 with -25. I did drain the water out, cleaned the filter and also the rear exit water filter and still same error. Any idea?
Root Admin Whitegoodshelp Posted April 19, 2022 Root Admin Posted April 19, 2022 Hi. You need to work out if the pump is running or not. If it isn’t that’s one set of possible faults, but if it is then there’s likely to be a blockage somewhere. This article explains in more detail washing machine not draining water Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
