crispy Posted February 20, 2022 Posted February 20, 2022 Hi All, I have this washer dryer and recently its stopped drying properly. Clothes are hot but damp. I opened it up to see if there was a condenser and noticed the plastic channel seemed very clogged up. In order to clean it I assume I have to remove the Heater Channel Group at the top which seems to be secured with 4 large torx type bolts. Does this all sound correct, doable? I tried to find a service manual but no luck Thanks for any help :-)
Root Admin Whitegoodshelp Posted February 21, 2022 Root Admin Posted February 21, 2022 Hello there, yes repair manuals are just not made available to the public. You should go to take off the cover with the correct talk schools but early mind that if you find it has been sealed with the sealant you would need to replace it with special heat resistant sealant. Have a good look at this article first in case it helps Clothes come out of drying cycle hot but still wet The big plastic container at the back is just where the condensed water runs back into the bottom of the drum in order to be pumped out. If it is blocked at the bottom where it enters the drum then it could definitely cause this problem. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
crispy Posted March 5, 2022 Author Posted March 5, 2022 Thanks Andy. I took a leap of faith and unclogged the condenser and fingers crossed all seems good now Cheers Whitegoodshelp 1
