Assaf Posted September 21, 2021 Posted September 21, 2021 Hi Guys, thanks for accepting me to the forum. I had this light blinking on my machine. did the following: 1. checked water supply: OK 2. checked flow rate: OK 3. checked the filter: OK 4. checked the waste pump impeller for free movement: OK 5. checked the drain hose: OK the light still blinks. I took the power plug out again, took off the inlet hose (with the solenoid) from the faucet, and put it back up. I put the power plug back in, now the light went off. This made me suspect that maybe the solenoid is on the edge... Anyhow, I used the opportunity that the machine is out, to clean the water inlet assembly. took it off, cleaned it, and put it back in place, not forgetting to plug back in the flow-through sensor connector. I connected the machine again, and again the light starts blinking. So now, I start thinking it could be the water level sensor. So next thing I do, is I place the machine on its back, so I can investigate forward. After a bit of wondering, I understand that I'm stuck, not really knowing how to get to the water reservoir So I decided to put everything back in place and search for further help. but just before I head up to post this, I try one more time, and now it's working again. bottom line: I'm pretty sure I'm running on fumes here... so any tips on how to deal with this, so I can prepare before it happens again, are appreciated Thanks
Root Admin Whitegoodshelp Posted September 22, 2021 Root Admin Posted September 22, 2021 Hi Assaf. If a washing machine thinks there's a water supply problem when there isn't - i.e. water is running into washing machine drawer ok then it's possible the system that detects when water is inside the machine and the water levels is faulty. Commonly it can be caused by gunge blocking the pressure chamber bottle in the drum. But you need a full understanding of how it all works, there's some hints here faults on pressure system but other things could cause it too. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Assaf Posted September 22, 2021 Author Posted September 22, 2021 2 hours ago, Whitegoodshelp (Andy) said: Hi Assaf. If a washing machine thinks there's a water supply problem when there isn't - i.e. water is running into washing machine drawer ok then it's possible the system that detects when water is inside the machine and the water levels is faulty. Commonly it can be caused by gunge blocking the pressure chamber bottle in the drum. But you need a full understanding of how it all works, there's some hints here faults on pressure system but other things could cause it too. Hi Thanks, just to make it clear, I'm talking about a Dishwasher....does this keeps your answer relevant? I now understand that I havent made it clear enough...
Assaf Posted September 22, 2021 Author Posted September 22, 2021 2 hours ago, Whitegoodshelp (Andy) said: Hi Assaf. If a washing machine thinks there's a water supply problem when there isn't - i.e. water is running into washing machine drawer ok then it's possible the system that detects when water is inside the machine and the water levels is faulty. Commonly it can be caused by gunge blocking the pressure chamber bottle in the drum. But you need a full understanding of how it all works, there's some hints here faults on pressure system but other things could cause it too. OK so I just now realized that Im actually in a washing machine forum... can you recommend on a european dishwasher support forum? Thanks
Root Admin Whitegoodshelp Posted September 22, 2021 Root Admin Posted September 22, 2021 Aye. Dishwashers are very hard to work on and many parts are very hard to get to plus it’s not advisable to lay them down. If still keen try ukwhitegoods.co.uk Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Assaf Posted September 22, 2021 Author Posted September 22, 2021 1 hour ago, Whitegoodshelp (Andy) said: Aye. Dishwashers are very hard to work on and many parts are very hard to get to plus it’s not advisable to lay them down. If still keen try ukwhitegoods.co.uk Thanks, I tried...for some reasone Im not able to create new posts there, even though I registered...Ill try asking admin
