Ok so I have a hisense washer dryer which works fine when just washing but when I put into a drying cycle it throws an f17 error which I’ve read means no water is getting to the condenser.... any ideas on how to fix it?
Hi. If water is otherwise getting into the washing machine and it washes and rinses ok then it is likely to be the solenoid that supplies water into the condenser that's failed or a blockage inside the entry to the condenser. If the solenoid is a double or triple water valve you would most likely have to replace the whole thing.
