Cflip Posted April 16, 2021 Posted April 16, 2021 Hi The filter cap on our machine is stuck. Last time this happened it was blocked but could be removed. From looking online and at the articles it seems likely something is stuck in there but there are no front access screws easily accessible to remove the filter so we can't disconnect it to check. They appear to behind the entire front panel of the washing machine which is proving tricky to remove. Please see photo of filter access point. We have turned it on its back to try and access it underneath but can't see how to detach it as screws are clearly holding it in place. Any experience with how to do this with this type of machine? thank you for any help in advance!!!
Root Admin Whitegoodshelp Posted April 19, 2021 Root Admin Posted April 19, 2021 Hello there. Yes something could be stuck inside and preventing it from unscrewing. I've had it several times and it's usually been underwires from bras. If it will not unscrew you have to take the sump hose off from inside as described in my article here How to remove washing machine pump filter. There is a section on this article specifically for if the pump filter is stuck. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
