Hi there,
Wonder if anyone can help me. Moved into a property with a inbuilt washer dryer by Beko. Model wdiy854310. We've never got it to work and I have a basic electrical knowledge but all the tools as a sparky.
The machine when turned on from the mains is completely dead, no noises, no lights. I've seen other posts but they usually have signs of life. My white goods repairer just said buy another one but money is tight at the moment.
I've tested the best I can and found the flex into it is live but stops at the back of the machine and appears to go nowhere else. Leading me to believe the bottom PCB is broken.
Anyone have any ideas or advice, is it worth replacing with limited knowledge or buy another machine? I'm one of these who likes to fix it if it's broken rather than give the manafactuers the pleasure of having to buy again.
Cheers in advance
  • 2 months later...
Hello there. Sorry for the late reply. You've probably got it fixed by now but the power should go to the on off switch and the control panel and then when that is switched on down to the door lock. But you are right to say that if everything is completely dead then it could be problem with the power supply in the main PCB. You would also need to test to make sure that there is a neutral return to the plug socket. You can easily do that just by plugging the washing machine into a totally different wall socket that you know is definitely working.
