Hi.  This Washing Machine has decided to play up. It keeps changing settings all the time and we can't use the machine. I have tried all the usual turning off at mains etc without any luck. It's the LCD display red light that keeps changing time and other settings. It won't remain on one setting.
If it's a repair person that is needed so be it. Probably cheaper to replace it.
Kind regards Denn
Definitely not a diy job. Could be a connection problem or a fault on the PCB and/or display panel. Apart from trying another socket just in case of a weird supply fault but that’s pretty much a long shot. Earth faults at the socket have been known to cause weird faults.
