hi guys. i have a bush f721qb washing machine which i have replaced the door seal. so i have put it back together and all im getting is start light and stop lights are just flashing?
i also have another bush washer sa127qw which works fine. as both front panels are exactly the same i swapped the mainboard from the good one to the bad one and it works. no flashing lights.
so i tried the bad one in the good washer and it works fine too???? but when i put oit back into the first washer same thing just flashing lights???
can anyone help with this?
Hi. I would check all of the connections and wires to the board in the first one.
Hello Dave. If a part doesn't work in one machine but it does in another then it's highly likely that it is the connections or wiring, especially if a replacement part works okay as you described. I honestly can't think of any other explanation.
