Hi guys,
Thanks for any suggestions.
If I run a program, the drum fills with water until the Rinse lights starts to blink. It then continues, stops blinking…. Various noises in the upper left.. then after about a minute from the start of the program – the machine then successfully empties the drum of water while displaying the “- - -” message in the display. The Rinse lights continues to blink.
The pump is clearly working correctly
There is nothing stuck to the pump itself to slow it down
The filter is clean
Water into the drum is working
Soap dispenser is clean
Water into the soap dispenser is working
Water pump / evacuation is good
The sump tube is good and no blockage
There is no water in the bottom tray apart from the normal amount when I remove the filter plug.
I have now removed the front cover of the machine and there is no water in the lower tray where the water sensor is – all is dry.
At no point does the drum turn
All cables visible from the top seem ok – nothing broken
If I run the Wool (cold wash), it seems to count down from 39 minutes – but the drum never turns – nothing happens except the timer counts down.
On other warm washes it normally takes about 2 or 3 minutes before the rinse light comes on, the pump starts to drain the drum and the display shows “- - -” and the unit stops
What else could be triggering the error?
I read somewhere that it could be a loose cable to the drum but I cannot see anything from the top – the drum never moves.
Thanks in advance – it is an old unit but very good. The cost for a local technician is very high so I prefer to repair this myself while impressing the wife.
  • 3 months later...
Hi. This is an old topic which didn't get a response because it was posted in the wrong forum. I just found it in the consumer forum and moved it here. I'm pretty sure the fault has been fixed by now or you got a replacement but just in case it helps others with the same symptoms can you give us an update?
The first question I would have asked is does the motor turn on a spin only cycle? And if not I would check the motor first for worn carbon brushes (if fitted).
