i all, hoping you can help please!? My machine is not spin drying and is flashing rinses. The brushes have been checked and are ok. If the machine is empty it will complete the wash cycle fine with spinning. A few clothes in the machine and it will spin dry ok. And a few more it gets stuck. It seems to be a weight in the drum issue. It doesn't seem to be washing as well either. Same issue weight in the drum. Hope this is a simple one! Thanks, John
  • 3 weeks later...
Hi. The video isn't working?
Also check that the drive belt isn't slipping. It would need to be quite loose for that to happen though. This article describes how tight the drive belt should be
