My washer shuts down at random times mid cycle including the display.
If I turn off power and wait for about 1 min before I turn power back on, the machine runs and then stops after a while.
I checked the door, it functions normally (locks and unlocks).
What could be the reason?
Hi. First thing is to try it in a different wall socket. It’s a long shot but you have to eliminate the basics first. Sounds like a power supply problem.
The video makes it look like a pcb fault on the power supply but I would not recommend speculatively replacing it as there's no guarantee it will fix it and they are expensive.
There is no actual socket. It has a connector that is controlled by a 20A wall switch.
I am thinking that it may be  bad capacitor(s) on a PCB.  Why would it function after I wait a while before  I turn the power back on?
Does anyone know if a faulty sensor can manifest this behavior?
Hi Ben, yes it could be something like a poor connection or faulty component but appliance engineers aren't taught how to repair PCBs only replace them so it's unlikely an appliance engineer can help. There is a discussion about a Beko washing machine that is dead and turned out to be a specific component that dozens of people have fixed thanks to someone who understands electronics posting a solution. Yours could be a similar thing -
