RobShep Posted August 16, 2020 Posted August 16, 2020 hi, we have a Samsung P1253S At the back of the filter Compartment at the bottom is some kind of paddle thing. it sits on the end of a spindle and my guess is that is mashes cruft around so as not to block the drainage. the paddle has come off the spindle and makes a horrendous clanking noise as it occasionally catches. Ive removed and the washes operates fine (On a spin) for now. Some questions if I may..... what are the consequences of this thing missing from the washer? is it repairable? Or replaceable? is it part of a field replacement kit for a larger component maybe? any insight, gratefully received. thanks Rob
Root Admin Whitegoodshelp Posted August 16, 2020 Root Admin Posted August 16, 2020 Hi. I might be misunderstanding but it sounds like the pump impeller which if it’s come off the shaft will mean the pump will no longer pump water? RobShep 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
RobShep Posted August 16, 2020 Author Posted August 16, 2020 36 minutes ago, Whitegoodshelp (Andy) said: Hi. I might be misunderstanding but it sounds like the pump impeller which if it’s come off the shaft will mean the pump will no longer pump water? Great, You are right. Thanks a lot. Knowing the right terminology helps. an image search for leads me to match it up exactly. now I know what’s up I can find spares or help or both. thanks again Rob
Root Admin Whitegoodshelp Posted August 16, 2020 Root Admin Posted August 16, 2020 Usually if the impeller has come off you will need a complete new pump. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
RobShep Posted August 16, 2020 Author Posted August 16, 2020 4 minutes ago, Whitegoodshelp (Andy) said: Usually if the impeller has come off you will need a complete new pump. Thanks A new pump kit is £40 so I’ll swap it out. couldn’t find one on the affiliate site above but have found one in the U.K. Cheers. Whitegoodshelp 1
