Hi, I have a Hotpoint Aquarius AQD1170D697E washer dryer.
When put on a wash cycle the machine gets to 3 minutes then resets back to 49 minutes. I then check to see if the conditioner has been flushed through and it hasn't. 49 minutes is the amount of time it takes to complete a Rinse and Spin cycle.
When I put the machine on a Rinse and Spin cycle, the machine will flush the conditioner through and finish this cycle.
Is this the main board (P.C.B)?
Thanks in advance!
Not necessarily, quite possibly not. One suspect is the heating element. Advice on testing g one can be found here - Not heating
Hi! Thanks for the heads up!
I have measured the resistance of the water heater coil, it measured 30 ohms. I also checked the resistance to earth and it was open circuit.
So could you shine some light on this one please?
Cheers!
