Curious Posted May 19, 2006 Posted May 19, 2006 Hi. On tumble dry, the drum turns but the clothes aren't drying. They come out still damp and cold. Any help would be much appreciated.
Root Admin Whitegoodshelp Posted May 19, 2006 Root Admin Posted May 19, 2006 You can unplug the washing machine and take off the lid. Check for a resettable TOC. It's a small round, button-like device, with 2 wires on it. All the dryer parts are on the top of the tub. If there is a small rod in the center of the TOC you may be able to reset it by pressing it down and it will click if it's been cut out. If not, you would need a continuity test meter to check the continuity of the toc's, stats and heater on the dryer section. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted May 19, 2006 Author Posted May 19, 2006 You STAR !!!!!!! Problem sorted ! There are two of these TOC's with little buttons in the middle of which the front one clicked when I pressed it. Why would this have tripped out? Can I give the Missus a slap for overloading it?? Is it likely to happen again? You've probably just saved me a large repair bill or a trip to go and buy a new one
Root Admin Whitegoodshelp Posted May 19, 2006 Root Admin Posted May 19, 2006 It's possible it was something to do with overloading. Washer dryers can only take small loads on the dryer side. ( Related: Which is the best - a combined washer-dryer or separates? ) If it happens again, there may be further investigation needed, but hopefully it wont. If the TOC trips out again then there's likely to be something causing it which should not be ignored. TOC stands for thermal overload cutout, and is the part that stops a washer dryer catching fire through overheating. It's a vital part that should never be bypassed. Common causes for the TOC on a washer dryer cutting out are - Too many clothes in drum (a washer dryer will typically wash more laundry that it's capable of tumble drying) No cold water supply to the condenser compartment (usually a faulty valve) The washer dryer fan isn't running (note on some Zanussi washer driers the dryer fan doesn't start running for several minutes but the vast majority should run immediately) Buy washing machine and washer dryer parts Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
