Mr washer Posted May 1, 2020 Posted May 1, 2020 Hi all new member here, when using drum clean programme I know I have to press auxiliary button 1 for 3 seconds but what program do I set the programs dial to? thanks in advance
andyr12345 Posted May 3, 2020 Posted May 3, 2020 On 01/05/2020 at 14:00, Mr washer said: Hi all new member here, when using drum clean programme I know I have to press auxiliary button 1 for 3 seconds but what program do I set the programs dial to? thanks in advance Hello there - you didnt specify what make model of washing machine but I predict once you press the aux button for 3 seconds it will matter not what programme you have the dial set to and just go into its normal automatic drum cleaning programme/cycle. Normally for about an hour Drum cleaning is a very hot wash of about 90'c heat , vigorous drum action , then rinse (or more than one rinse) maybe a spin of about 400rpm or 600rpm then end. Whitegoodshelp 1
