Hi I'm looking for help, I have a beko washer, I have put it into service mode, i select the option to spin the motor right and then left, it's meant to spin slowly but goes on full spin speed, would this suggest the pcb dc motor board needs replacing?
Thank you for any help
Pete
It could be a PCB fault but it could be the tacho magnet on the motor that’s come off or broken.
There is information about motor tacho coil here - tacho coil on washing machine motor although if there are no carbon brushes in your motor it probably won't have a tacho coil.
