I recently replaced the water drain motor which was leaking.  After replacing this part, the leak stopped but now see that water is coming from the filter drain hose during any wash cycle.  This is the hose located in the bottom left hand corner that comes out when you open the small white door.  This door hides the round filter that unscrews when you want to check the drain area for objects too large to drain out normally.  This never happened in the past and wonder why this has started immediately after I replaced the water drain motor.
Any ideas why?
I presume you mean the emergency draining hose. Is it leaking from the front or where it attaches to the pump?
