Hi  My brother has just fixed my Bosch Washing Machine Error Code 23. But now needs the combination to clear the front display panel , Please can anyone help. Thanks June  Ps  Bosch are coming on Tuesday call out  charge £90 greedy
Normally any error code should clear as soon as the fault has been fixed. An error code is triggered when a fault is detected but if fixed it should no longer detect the fault.
Hi there was water on the float  and lots of rubbish behind the blue disc  . All fixed  I need the code to reset.  Please can any one help  Thanks June
There isn’t any code to reset that I know of. Otherwise every time a fault occurred on a washing machine we’d have to get an engineer to reset it. Are you sure the float switch is not still stuck on?
