Adamj Posted January 20, 2020 Posted January 20, 2020 Hi there looking for some help on sorting the door seal on my machine candy bianca as door seal leaking (spring loaded wire has popped off Interior in drum )any help would be appreciated or if this is an easy fix or would recommend an engineer or specialist, thank you
Root Admin Whitegoodshelp Posted January 23, 2020 Root Admin Posted January 23, 2020 Hello. The wire holding the door seal onto the drum? That should never come off. I'd be concerned that there is a cause of it coming off such as the drum banging about violently? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Bianca Posted July 9, 2022 Posted July 9, 2022 (edited) I made an account just to comment on this one. I also have a Candy Bianca "not-so-Smart" Washing Machine. Here's the best tip: NEVER buy this piece of garbage! The spring loaded wire also popped of with mine. Multiple times. It wasn't even tight from the beginning. Just look up a clip on how to change the rubber seal, fixed in couple of minutes. This machine is nothing but TROUBLE. Too many issues to sum them up or go in detail. (Randomly non-responsive, wifi not working, door locked for days, ON/OFF doesn't help, pulling the plug for some time (maybe hours) is the only solution, spring loaded wire popping off... ETC.) I'm surprised this machine found it's way to the market! Absolutely unbelievable. I hope i saved someone a lot of frustration by NOT buying this machine. Cheers. Edited July 9, 2022 by Bianca
ikeo Posted March 11, 2023 Posted March 11, 2023 On 09/07/2022 at 19:50, Bianca said: I made an account just to comment on this one. I also have a Candy Bianca "not-so-Smart" Washing Machine. Here's the best tip: NEVER buy this piece of garbage! The spring loaded wire also popped of with mine. Multiple times. It wasn't even tight from the beginning. Just look up a clip on how to change the rubber seal, fixed in couple of minutes. This machine is nothing but TROUBLE. Too many issues to sum them up or go in detail. (Randomly non-responsive, wifi not working, door locked for days, ON/OFF doesn't help, pulling the plug for some time (maybe hours) is the only solution, spring loaded wire popping off... ETC.) I'm surprised this machine found it's way to the market! Absolutely unbelievable. I hope i saved someone a lot of frustration by NOT buying this machine. Cheers. Man can you please provide a link to the clip? I'm about to give up and buy another washing machine due to this. I wanted to clean the seal and this thing popped out.
