I have the error code f03 that is intermittent. I've changed the element but that hasn't cured it. It's strange that the machine often continues working for a while after the code apears (along with all the indicator lights flashing). Any suggestions welcome! thanks
Hello. Error code F03 on most Hotpoint washing machines is related to the NTC. This article may help - Hotpoint error code-F03
Thanks for your reply. I've already changed both the element and thermistor. Would it likely be a wiring issue then?
It can be a connection fault or break inside one of the thin wires.
