Natc2911 Posted January 15, 2020 Posted January 15, 2020 The brushes needed changing on our bosch Waq243 which I done. it spun first couple of times after but now it try's to go into a full spin and then stops as if it's out of balance but it will do this over and over even if there is nothing in it, I've checked the brushes again and they are fine any suggestions?
Root Admin Whitegoodshelp Posted January 15, 2020 Root Admin Posted January 15, 2020 Have you fully removed the brushes to make sure they are not charred or sticking and are making good contact with the commutator (shiny)? This article may be of use Problems after fitting carbon brushes Also check the motor plug and try putting a normal load of laundry in, just in case it doesn't bother spinning with no load inside. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
