My Beko washer overfills on the second fill on all programs I have followed some of the guides I have fitted a new pressure switch and tube also checked the chamber by blowing brown pipe all seems that it isn’t blocked as I can hear the water bubble any ideas
thanks
Daveo W
Hello Dave. It seems very strange that it would only overfill on the second fill. When you see that it is starting to overfill and you turn the washing machine off does the water stop running in? If it does then that suggests it is a fault on the pressure system somewhere rather than a sticking water valve.
A small air leak could theoretically account for overfilling that takes more than one fill to do. One way that might manifest itself is if the washing machine initially stopped filling up, but then shortly after fills up a bit more, then stops, and then fills up a bit more and so on. Test for this without washing inside as when laundry soaks up water it often tops up a couple of times anyway and might mislead you.
