Jenna Posted November 5, 2019 Posted November 5, 2019 Hi there I have a Bush F621QW and it keeps coming up with Error code 3 stating that i need to clean the pump. I have done this multiple times today and it still keeps coming up with the same error and stops halfway through a wash. Is there any advice you can give me to fix this as I am a little reluctant to just go out and buy another machine if its something that can be easily fixed myself. Thankyou. XXX
Root Admin Whitegoodshelp Posted November 6, 2019 Root Admin Posted November 6, 2019 Hello Jenna. If the error code 3 means you need to clean the pump but you can't find anything inside the pump or the pump filter then either the error code 3 doesn't mean clean the pump (or maybe could mean something else as well), or there is another fault that is stopping the water from pumping away and it's not simply that the pump needs cleaning. The main thing I would say is when the washing machine comes up with error code 3 and presumably stops is there a fair bit of water still inside the washing machine? If it has clearly not pumped away any or most of the water then there must be a fault on the pump or a blockage somewhere else. The only thing I can advise is to very carefully go through the entirety of my article, which covers every possibility that I can think of. There are also links within this article to other related possibilities. If that doesn't help them I can only suggest getting an engineer - Washing Machine Won’t Drain Water Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
