MDS_UK Posted September 11, 2019 Author Posted September 11, 2019 (edited) 26 minutes ago, Whitegoodshelp (Andy) said: Not sure why the door is off, but If you need to get an engineer in you need it all put back together. If a washing machine isn’t emptying water it isn’t usually this difficult to find out why. It seems like you’ve eliminated everything but then can’t have because if we had we would have found the cause. The only possible faults are - Something inside the main drum that is blocking the water from going into the sump hose Something blocking the water from getting from the sump hose into the pump (including the ball sticking). Try taking the ball out btw The sump hose itself getting kinked or collapsing due to worn or damaged suspension or somehow being fitted wrong A blockage in the pump filter, or in one of the chambers in or out, or round the impeller A blockage inside the drain hose A blockage after the drain hose such as at the u-bend if connected to one The pump impeller broken on the shaft or pump not running properly or at all For me the second video you uploaded shows the pump impeller is ok and the pump is running strong enough to pump water. I had to take the door off to remove the clips that held the drain pipe on the pump. It's all back together now, I tried the drain cycle and, low and behold, it pumped some water out into the pan. Not the full amount, but most of it. I've just put it on a 15 min cycle and I'll see what it does... Edited September 11, 2019 by MDS_UK Whitegoodshelp 1
Root Admin Whitegoodshelp Posted September 11, 2019 Root Admin Posted September 11, 2019 Nice one. Fingers crossed. MDS_UK 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
MDS_UK Posted September 11, 2019 Author Posted September 11, 2019 (edited) ARGH!!! OK - it's not the pump. I've just run a drain cycle and it worked fine. I've run a 15min cycle and it drained 2 full buckets mid-cycle but again get's stuck at 0:01. What on earth would cause this? EDIT - if it makes any odds, the 15 min cycle was a cold wash. Edited September 11, 2019 by MDS_UK
MDS_UK Posted September 11, 2019 Author Posted September 11, 2019 Video of it now - failing to drain.
Root Admin Whitegoodshelp Posted September 12, 2019 Root Admin Posted September 12, 2019 Hi. As I mentioned earlier, sticking on 1 minute is often the heating element. Not draining water is a totally unconnected fault. It seems like you've sorted the not draining but still have the sticking on 1 minute fault. They could be related in the sense that the heating element may have completely corroded due to the same limescale and gunge you found blocking the drain pipe. Try this article Washing machine not heating up water Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
MDS_UK Posted September 12, 2019 Author Posted September 12, 2019 1 minute ago, Whitegoodshelp (Andy) said: Hi. As I mentioned earlier, sticking on 1 minute is often the heating element. Not draining water is a totally unconnected fault. It seems like you've sorted the not draining but still have the sticking on 1 minute fault. They could be related in the sense that the heating element may have completely corroded due to the same limescale and gunge you found blocking the drain pipe. Try this article Washing machine not heating up water Yeh but given it's a cold wash, I figured the temp sensor wouldn't come into it... I've got a repair guy calling out tomorrow morning. As much fun as it's been dismantling it every night this week, I've run out of patience and time! I'll revert back and let you know what the outcome is. Thanks for all your advice! Whitegoodshelp 1
Root Admin Whitegoodshelp Posted September 12, 2019 Root Admin Posted September 12, 2019 Thanks. Please do let us know what it is. I would be surprised if the heating element wasn't knackered due to corrosion and limescale. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
MDS_UK Posted September 18, 2019 Author Posted September 18, 2019 Update - The issue was solved with a replacement pump! Bizarre that the pump worked mid-cycle but not a full drain! The repair guy said he'd never seen the issue before either. In any case, just pleased it's working and I haven't had to shell out £100s on a new machine! Cheers! Whitegoodshelp 1
