I have a Bosch Logixx 8 washing machine that washes as normal, but when it is centrifuged it stops and the rinse lamp flashes.
If I try without clothes it spins as normal.
I have cleaned what can be cleaned.
Taken a reset.
Can it be the brushes?
Best regards
Frank H.
Normally if a washing machine spins ok without washing in but not with washing in the problem may be related to out of balanced loads Not spinning some loads
Other possibilities are carbon brushes (which is t applicable for you), a slack drive belt or a fault on the PCB.
Thanks for your reply Andy :)
I did find out that one of tree cables for the balance sensor on the vakkum side was broken.
I tryed to fix it, but the contact is not easy to spare. Do you know if i can disconnect/remove the sensor?
Frank H.
Sorry for late reply. My notifications have been hit and miss. I've never tried to remove one. Make sure the drum is being loaded properly before suspecting the sensor.
