Ruth Posted July 26, 2019 Posted July 26, 2019 The emergency drain hose has gone inside washing machine and I cannot get it out . I pushed it back after cleaning and end bung came off and pipe disappeared. It is a Samsung eco bubble
Root Admin Whitegoodshelp Posted July 29, 2019 Root Admin Posted July 29, 2019 Hello Ruth. This seems to be a fairly common problem as there are several other topics the same issue. You probably need to remove the plastic kick strip that surrounds the pump filter at the bottom of the machine. This usually is clipped in and can often be carefully prised out. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
