I have already read through the washing machine common faults help guide
Hello, my Hoover Dynamic Next DXCC69W3 9Kg Washing Machine (4 years old) has suddenly stopped working. The display only shows rotating blinking lights on the display.
When looking up error codes, I expected to see E1, E2, etc as per the manual but there are no letters. I don't see any pattern in the flashing lights either.
When changing settings, it still beeps.
The washer information is here: https://service.hoover.co.uk/advice-centre/washing-machines/dxc-c69w3/
The manual is here: https://service.hoover.co.uk/manuals/DXC-Models.pdf
Here is a short video showing the issue. https://youtu.be/q-tWEoGftSc
Do you have any advice?
Thanks.
  • 10 months later...
  • 2 years later...
Normally, when all lights are flashing it means something has gone wrong with the system and it's gone a bit crazy. But a friend of mine had a washing machine where it said in the instruction manual that all lights flashing meant it hadn't drained the water out.
If it doesn't say something about all lights flashing in the manual then it's something the manufacturers haven't expected. It could be something like a system crash, or fault on the PCB or control panel, or a communication error between them. Not something with an easy diy fix.
