Bugtao Posted June 29, 2019 Posted June 29, 2019 My Hotpoint washer drier WDAL 8640 P door would not open and handle also broke. I replaced the handle and the interlock, but now it does not lock. The machine seems to know that the door is shut, but after a few seconds delay where I presume it is checking if the door has locked, the lock light starts flashing and a beeping alarm sounds. The door is not locking. Any suggestions?
Bugtao Posted June 30, 2019 Author Posted June 30, 2019 There seems to be no power getting to the interlock. I have checked with the connector to the interlock disconnected and there is no power across any of the 3 pins before or after starting a wash program. The machine starts beeping as soon as the start button is pushed.
Root Admin Whitegoodshelp Posted June 30, 2019 Root Admin Posted June 30, 2019 The power should come from the main PCB so normally you’d need the check continuity between all door lock connectors and the PCB. It’s possible the PCB is faulty but I wouldn’t recommend replacing it. They are very expensive and there’s no guarantee with them. You could try sending it to QER repairs if not prepared to give up but you’ve tried the normal diy friendly things. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
