Phil EVERSON Posted June 27, 2019 Posted June 27, 2019 Hi, I am hoping someone can give me some guidance. I have a Hotpoint WT540 washer, which is now stopping mid-wash, and displaying two flashing lights on the vertical indicator (position 2 and 4 - whichever way you read it - there are horizontal lights too, but these don't come on - wouldn't a fault be indicated on these?)). I have interpreted this (possibly wrongly?) as fault 10, pressure sensor / valve. I have replaced the sensor, and as far as possible checked the hose to it (I have blown down it, and can hear water bubbling, and I have pinched the very bottom of it, and can not find a leak or split on it when blowing again). Oh, the on on/off button flashes very rapidly when the fault kicks in Anyone got any ideas before I hit gumtree for a replacement machine?? Thanks Phil
Root Admin Whitegoodshelp Posted July 24, 2019 Root Admin Posted July 24, 2019 If the error code interpretation is correct it could also be a fault on the eprom chip or the pcb. Replacing parts in the hope it will fix a fault is way too risky. You have to work out for sure that a part is definitely faulty, but that can be very difficult - even for engineers sometimes. But at least an engineer will often have spare parts to try. If you have to buy each part it's a rabbit hole not worth going down. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
