Fraser Posted June 19, 2019 Posted June 19, 2019 Hi all, My Indesit IWDD7143 washer dryer has developed a rather peculiar issue where the drying part of the Express Wash & Dry cycle fails about two or three minutes in with an F13 error. I have replaced the NTC sensor in the heater assembly, and also cleaned the fan as it had quite a bit of fluff build up. Running a dry-only cycle or drying after any other programme works with no problems at all. I'm out of ideas on this one, hope someone can help! Cheers, Fraser
Root Admin Whitegoodshelp Posted June 19, 2019 Root Admin Posted June 19, 2019 The info I have, which is pretty old now though, says F13 is NTC faulty or dryer fan not running. If you've replaced the NTC at top of machine under lid check the connections. Double check the fan is running when it goes into dry after the wash cycle. If the fan is running, blockages can cause it to overheat such as build up around the fan (which you've checked) or maybe down in the condenser chamber where the air is blown to mix with the stream of water to condense into water. Make sure there is a trickle of water running into the condenser chamber as if it fails the whole thing will steam up and overheat. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
